Foot switch....
8T6K5
AZ
L98 350 TPI
Picked up an old foot switch...
I want to re-wire some aux lights to it.
Switch has 3 wires coming from it, A - B - C on the switch.
Im guessing one is power in - power out and ground...??
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Yellow - dimmer switch feed
Lt grn - high beam
tan - low beam
8T6K5
AZ
L98 350 TPI
Soooo....
I would use green for lights and yellow for 12v power in?
Tan?
RetroC10Sport
Jay
pontiac aztek
Sounds right. Tan for a second set?
Now you're giving me ideas.
8T6K5
AZ
L98 350 TPI
Might just pull right off the new dist block and use a relay just so theres a ground...??
Sould be a fun mess...
That's a weird plug. What did you pull that from?
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Ive been wantin to do the same thing with my lights that are on my front bumper.
8T6K5
AZ
L98 350 TPI
J Knight
Baytown TX
82 Chevy
350ci
Soooo....
Tan?
You would only be able to use one curcit at a time. Power one set of lights to the green and one set of lights to the tan and alternate to either or but not at the same time.
Old C10...honestly dont remember
Interesting, my 70's trucks have just a regular looking plug. Must be an early 80's thing.
Driver4r
Nebraska
Trevor
k10,c20
If its from a roundlight, arnt both our lows and highs on at the same time????
So why cant he run both.
J Knight
Baytown TX
82 Chevy
350ci
That has nothing to do with the dimmer switch, they are on simultaneously because of a jump wire(factory) at the headlight plug.
Ewwww, I'm loving this idea. All my trucks are 84 or later so they are Multifuncion Switch. I can add a foot switch too for Aux lighting too. That's a badass idea.
I always wanted to install one for an Ejection seat and Electronic Door Popper. The bitch get's mouthy, I stop, hit the switch, door pops open, seat dumps her out, nail the throttle to take off, the door closes and problem solved !!! No more whining and bitching. :waytogo:
J Knight
Baytown TX
82 Chevy
350ci
Got to remember one thing, if you run two different things in this switch you will have to put a toggle on the power source to turn them both off.
Corncob
