Foamy oil
Copper Jr
Missouri’s
william
So I was getting to work on my choke and noticed this. I plan on changing the oil should I replace PCV
Camar068
10 yrs Air Force
kinda looks like what comes out of my oil catch can I have hooked up to one of the valve covers on my LS.
78C10BigTen
pennsylvannia
C10 BIG TEN
Bad head gasket was my thought. Usually thats the culprit.
Copper Jr
Missouri’s
william
Are head gaskets an easy job? And any brand recommendations?
78C10BigTen
pennsylvannia
C10 BIG TEN
Well youd need to put it on top dead center and pull the distributor, intake, valve covers then heads... for starters. Im gunna stop there because i do this backyard mechanic like. Others are super about doing it correctly and by the book. I just change gaskets and make sure surfaces are clean and smooth then reassemble and torque in sequence by the book. I dont check block or heads for true-ness and i reuse head bolts. Its really not too hard. Ive done it in the drive way under the shade tree. Some one better will tell you more im sure :D
Dutch Rutter
Independence, Or
Joshua
Does the oil on the dipstick look the same? If that looks fine it could just be a build up of condensation in that breather. If the oil on the dipstick is also milky then its most likely a bad head gasket. Loosing coolant is also a good sign of a bad head gasket.
Copper Jr
Missouri’s
william
Dipstick is good and coolant is good, going to change oil in the morning and pcv/breather see how that works out.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I have gotten that(Condensation) on a few vehicles(on the oil caps). Usually relates to humidity and typically for me when the engine had the longer oil fill necks.
If the oil comes out looking like that then its a big problem.
Copper Jr
Missouri’s
william
We will see in the morning let’s hope not.
1. Meh.
2. Fel-Pro.
I've seen that in LOTS of VW's that did not use a detergent oil and their crankcase breathers were all gummed up.
Changed all of their filters, changed the oil; end of milkshake. Easy fix.
Hope it's not a blown head gasket.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'll suggest something no one has suggested : how often do you drive it?
Do you just fire it up and drive it down the driveway the shut it off?
running the engine for short periods of time then shutting it off causes condensation in the crank case and motor.
MikeD
