Flywheel help
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Will a Flywheel from a 79 350 fit and work on a 96 vortec 350? Oreillys shows different part numbers for the 2 trucks So iwould assume that they wont interchange but if anyone knows for sure would appreciate it.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I am going to say no, in 1986 (I think) they switched over to a one piece rear main seal. The older motor will have a 2 piece and they require different flywheels.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
yea it was either 86 or 87 when the went with the 1 piece rear main seal but I wasnt aware that the flywheels were also changed. Thanks that sucks balls there goes another 75 bucks lol
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Ya know, im not even even sure of the difference. Im talking about manual flywheels, if you have a flexplate maybe it will transfer over.... Grey area there.
The '86-up motors have the one-piece crank seal and the flange is a different size because of it. The newer flywheels also have a balance weight on them.
85k10383
Glengary, WV
Ross
K10 Scottsdale
Yep, what he said^^ The newer motors flexplate has a smaller diameter hole for the crankshaft. Found that one out the hard way myself.
