Flex plate/converter problem
73K20
Jake
The Flex plate flexes. In and Out. So there is supposed to be a small amount of movement available for the torque converter to move in and out.
It was the sound and no go in gear that had me set on a mashed pump
So should I remove the shims I used? 1/4" of play is acceptable?
And ya that's what I was afraid it was but I knew that torque converter was seated. Lol. Glad it was my own exhaustion this time.
1993 F250 460 waiting for diesel swap-my 1st truck
1973 K20 6" lift-totaled
1967 F250 2x4-building a 460 to drop in
1977 K10 lifted, mildly built sb400
73K20
Jake
So what about the starter. High pitch whine when I start it. Which way do I need to shim it?
73K20
Jake
Cool thanks
350runner
tx
Ceasar
No prob
MadOgre
NA
NA
NA
NA
NA
Yes remove the 1/4" shims I have had to move the converter forward to mate to the flex plate every time as well. No kidding :)
You want 1/8 inch clearance between the flexplate and the shaft of the starter. Easiest way to check clearance is with a drill bit.
73K20
Jake
Cool trick. Thanks
prenrag
