Flex Fuel Information Wanted
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Hey all.
I know this isnt really squarebody related, but i am looking for some information... perhaps someone here has a flex fuel vehicle they own and could give me some input.
Out of curiousity, does anyone have the working voltage range on input and output for these flex fuel sensors?
I know the 2nd and 4th one are both for GM... the connectors are all the same, the pipe diameters change....
13577429 , 13507128 , 13507129 , 13577394
The 2nd one seems to be easily found on amazon for 56$ with a connector for 10$
Any info would be appreciated.
Everything ive read seems to suggest that the 13577394 is 3/8" input and output gas line, and has a 5v signal
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
5v is usually a signal wire voltage, 12v usually- diameter may actually be the only difference between generations
yellow81
