first time painting (pics)
86chevyk20
Buffalo
Liam
hey guys heres a pic of my fender i painted, sherwin willaims have me a great price on a pint of base and clear to test it out i guess im starting to paint my k20 now. I choose a dark blue, and it is dark but with the lights it looks lighter.
I practiced on an old hood and got the feel of the gun. i love useing a gun. when i layed the first coat of base i was like AHH tiger stripes but with the 2nd coat and drying they went away. I just got 2 light spots i gota scuff up and do again.
i think it tured out really good for my first time with a gun, now i just gota fix the orange peel issue. advice????
Swims350
Logan WV
none
wetsand and buff.
it's hard to avoid ALL orange peel and such unless you got a both, completely dirt free, very experiences, gun setup perfect and perfect paint mix etc.
I spray em, sand em, and buff em.
looks alot like my blue, it's darker tho, maybe it's your lights and mine will be lighter too in the lights, I aint sure. I haven't painted anything with it yet just saw the color chip.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i use to be a painter in a body shop
to avoid orange peel in clear coat you have to spray it wet at a higher pressure with the gun close to the body and move pretty quick across it.
almost to the point of the paint running it is a experiance thing. you run alot until you figure it out. the wetter the paint the more time it has to lay out smooth its self out before it dries. and do not have the room to hot or the paint will dry to fast. and to cold it takes forever to dry. and i like to use the slower reducers to give more time for it to lay out. just takes longer to dry.
maybe just try spaying it a little more wet no dry spots while spraying
i rarely buff anything i paint now after a couple years painting in shops i became a pretty good painter and i still do side jobs for people
86chevyk20
Buffalo
Liam
thanks for the advice. im happy with how it turned out for my first time. when i layed the first coat i saw striping and got scared that i screwed up but as soon as it dried it went away.
question... are the harbor freight guns worth useing to paint my truck, im not talkin the $15 im talking the $30 one or higher. I know they are not total crap and have seen people do some pretty awsome stuff with them
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
:popcorn:
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Looks good dude! Alot better than my first paint job.
Swims350
Logan WV
none
every paint job I've done has been with a $50 devilbiss paint gun from lowes.
Jims86
Patterson,Ca
5.7 TBI
So, what would you recommend as a good temp....round 80ish?
Swims350
Logan WV
none
at least 70's IMO.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i have used 900 dollar guns and the cheapest guns
i have a set i got from eastwood devilbiss guns 100 bucks for 2 guns. i love them set them good and if the are spraying good they are just as good as the 900 dollar guns.
the cheap chinese guns are only good for primer.
and 70 to 80 is a good range.
DREAMER
Baytown, tx
Dreamer
High Sierra
The actual painting is only 50% of the job. The prep work is the other 50%. Use a blow gun to blow all the dust out of your garage. Sweep it. Blow it again. A little water on the floor. Wipe down your truck. Get your truck into the garage then wipe it down again with a Tack-rag. Those are just some of the steps you should take.
I agree, the wetter the paint the better. But don't be discouraged...nobody gets "it" the 1st time
Swims350
Logan WV
none
yes as well as bug spray the entire area, it helps keep down on insects somewhat.
The main thing would also be the ceiling, dust stays up there in areas and when the paint over spray goes it, it locks on and pulls it down right into the paint.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I applaud you Liam! I think that's pretty friggin good for a first timer. It's nothing some wet sanding a buffing couldn't clear up.
EDIT: LOVE the color too!
Obullard74
