First time clutch replacement.. any tips?
dangOl'dodge
canada
C
r10
4.3 tbi
so i have my 93 nv4500 ready to go in my 87 c10, 4.8 swap.. just dropped the 4l60E and pulled the flywheel off.
I've never replaced a clutch before i was wondering if anyone could give me some pointers, such as the correct mounting order of everything, places to grease, what to clean before starting, etc...
i have these parts new:
flywheel
flywheel bolts
clutch kit
slave/master cylinder
clutch fork
pivot ball
this transmission has removable bellhousing with external slave cylinder, and a metal plate that wedges between the bellhousing and engine block somewhere along the line. not really sure on the procedure
Thanks again
flywheel
flywheel bolts
clutch kit
clutch fork
pivot ball
Thanks again
I found some videos. However, I imagine you've seen these already. I wish I could offer more, but my knowledge is very basic on this topic.
[yt]tS4H4oImDhE[/yt]
[yt]SaWnu9d6Ezc[/yt]
