Finally got a running 65 C10
1low4x4
Nick
That clarifies it thanks.
Dealing with a big oil leak on my 2021 single cab long bed Silverado with the 5.3. Almost to 80,000 miles and it leaks like an 8 inch diameter circle in 30 minutes. I just put a quart in it.
Likely it hasn’t dropped a lifter or screwed up the transmission like my wife’s 2020 trail boss. It’s been five grand doing a DOD delete with a new cam and lifters, and now the transmission is going out or at least the torque converter is. 80,000 miles as well. I just don’t make them like they used to. The LS platform was the last great one.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
That's ridiculous dealing with that at 80k miles
1low4x4
Nick
Well I broke a tooth on the comp cams timing chain sprocket.
Im tempted to just run the damn thing, you can see I’ve already installed the chain and was getting ready to install the front cover before I had second thoughts…..****!!!!
This sets me back 80 bucks and a week
Moderator
Ok, I'm really curious as to HOW you did that?
Personally, I'd run it. I'd say there's a 99.9999% chance that it would never cause an issue.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Just make sure there is no burr or raised area that might rub the chain from the break.
I think you'll be ok to run it.
1low4x4
Nick
Thanks guys, I went ahead and ran it.
Today I took my little 125 cc Grom to the local fire museum for my nephew’s birthday and then to the gym. Damn, I love that little bike. Since I sold my 1000 I still have to get out there and get wind therapy. Nothing like a James Taylor song on a spring day.
Bunch of stuff came in today, got the oil pan in, painted and installed. Was a booger getting all the bolts started, but I got them all in and snug. Of course the cam and timing chain are in, front cover back on. My head bolts just came in so I’m working on installing the new springs on the heads. Also, got the new speedo housing install installed. There’s no speedo gear in it yet, but at least I’ll be able to plug into it and stop the leak.
Really once I put the heads on, then I can do the intake. Put it back on the engine, hoist and mount the clutch and transmission back.
Also got new brass freeze plugs installed. Learned my lesson with my brother’s engine. Last time I installed it, had to hook the engine back up to the hoist, undo the motor mount, pick it up a couple of inches, remove the leaky rotted, freeze plug, and install the new one.
I need to find a freeze plug small enough to fit that hole on the top rear of the block that was once the crank case vent or whatever. Oil filler plug. Or both.
Sorry, three out of four of my photos were too large to upload so I will include them in the next post after I crop them
1low4x4
Nick
Question for yall. Cam kit came with springs, retainers, seals, and and the little locks or keepers….it didn’t come with these (pic in my hand) what are these called?
Moderator
Valve seals, or valve guide seals. Or valve stem seals. Depending on who you ask.
Turbo4whl
Downingtown, PA
Wayne
It's not that they are harder to shift, it's just that they cannot be shifted as fast. That's a lot of mass to get shuffled around in there. There ain't no bangin gears and chirping rubber.
I don't completely agree....
Moderator
Well I've been wrong many times in the past and I'm sure I'll be wrong many more times. If I could witness someone driving a 420 or 465 like a car type 4 speed can be driven, I'd be all giddy inside and very happy that my opinion was wrong.
Turbo4whl
Downingtown, PA
Wayne
Okay, for clarity lets call low gear first, then 2,3,4. Here is how: Start in first, mash the throttle, dump the clutch and the truck jumps. (scares anyone next to you!) Release the clutch, off throttle, straight pull to 2nd gear. Engine RPMs are just dropped enough it goes right in 2nd. Mash the throttle and the truck jumps a second time. Now the long shift to 3rd. Engine is still up in RPM and it goes in 3rd like butter. This is when the guy next to you catches up. But you have it in 3rd, and pull ahead!
Moderator
In this scenario, what is your shift rpm? Ever try a no-lift-shift with one? I have not been brave enough.
1low4x4
Nick
wonder why no new ones in the kit?
bajadiver
