Failed CA Smog. Looking for some direction
KelSMJ18
Redding, CA
Kelley
GMC V2500 Suburban
Hello all,
Took my 1989 GMC Suburban 5.7L 350 in today for its first smog. Did some tuning up on the burb and I've got it running well so decided to give the CA smog a try. Everything passed except a couple things:
1) Fuel Cap Functional: Fail (ok get a new fuel cap, easy)
2) Catalytic Converter: Modified (the cat on the vehicle is not California compliant so I have to buy and install a new cat)
and this is the one I need help with
3) Idle Emission Test Results: Gross Polluter
They ran a emission test on idle and the HC (PPM) that was measured reached 1008. The max allowable is 220. So I assume the vehicle is running very rich. My question is where do I begin to bring this HC (PPM) down. Attached is the Smog result. Thanks for the help!
Kelley
dd1990
Oxnard, CA
Suburban 1500
Could be alot of things,
I would check all wiring to sensors: 02, throttle, IAC, ignition and check injector spray.
Ive had rich idle turned out to be 02 sensor.
The cat you have now is it a high flow cat?
Lorenblazerk5
Los Angeles
Loren
k5
Great suggestion from Sad Sack.
California is super frustrating with regards to smog. That why I'm leaning toward 1975 and older to avoid the money grab.
I would work with a smog shop that can tune it so you will pass, normally a pass will be the worst set up for a smooth running engine.
Start with a good tune up, plugs, wires, cap rotor. Set the timing but retard the timing a few degrees. Retard timing will help clean up CO. That's one of the reasons the factory went to ported vacuum in later years and even timing specs that were after TDC. Not the best for performance and it makes the engine andvexhaust hotter. But you can re time it later.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
High hydrocarbons can be piss poor ignition or too lean a mix. Things to rule out, ya know. What were the CO, CO2 and NOx numbers? It all plays together.
Ain't that right @Ricko1966 ?
NLD79K10
Netherlands
Lars
As @Ricko1966 already said, start with a good tune-up as high HC with no high CO is most often indicative of an ignition issue.
Also check for any vacuum leaks and leaking injectors as that can cause the same issues, especially at idle.
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
Moderator
Finkaire
Finkaire
California
Loren
Silverado c10
Full tune up, plugs, wires, cap and rotor and then find a good tuner in your area
chris3353
idaho
chris
v2500
Hello all,
Kelley
Get Winaldl and the cable. Data log and check for errors in real time.
maybe timing, maybe a dripping injector?
Oldsnut
Maryland
Allen
R10 Suburban
Also check you temp sensor for computer. If it has failed it could be telling computer it is cold and forcing a very rich condition no matter what the O2 sensor is saying.
82SquareBurb
Soddy Daisy TN
Derek
Best advice ever! I remember the catalytic converter cartel in CA, same exact cats but with a carb number stamped into the side, with big $$ tacked on the price. Feel for those that get sucked into that con.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I bought this cat for $150 and it has a CARB EO number on it. Looks like it’s about $185 now:
You can ohm out your spark plug wires. Should be able to find how many ohms per foot they should be online. You can also test your coil. Visual on the plugs, though if you’ve gone through the trouble pulling them, I’d put a set of properly gapped new ones back in. The correct ACD plugs are still relatively cheap. The cap and rotor are similarly cheap, but again, I’d probably get the ACD ones.
All the ignition stuff should be $100 or so if you elect to fire the parts cannon at it.
Do you have a timing light? Find and highlight the marks on your balancer and tab. Disconnect the (brown iirc) wire near the steering and brake booster on the firewall and verify timing. The instructions are on the sticker on your core support.
Does being labeled as a gross polluter mean you can only go to a STAR smog check station now?
chris3353
idaho
chris
v2500
Forgot to say,, If you are failing at idle, Run the RPM to the exact maximum (~1400???)
I used to pass idaho, Cam, headers, hollowed out cat. If i let it idle at 600 it would fail
CubsFan79
