Factory wheels with positive offset.. or maybe negative offset on a dually? Good?
So I have 2 wheels, 16 inch I believe, that appear to be the front wheels on a dually truck that cone over the brakes and have little wheel past the hub, or maybe they are the exterior wheels on a dually.. Im thinking they are stock but I have no idea. I might have more than 2, but one currently has a tire mounted while one is empty rim. I can post a pic in the morning, but it looks like this
Its that, but rusty/white.
Are they worth anything, or do they have a good use? Is there something more heavy duty about them?
Would there be an advantage to using that wheel instead of 3/4 ton 8 lug
such as mine. I guess I dont know what purpose they serve besides rotational ability front to back/back to front
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
There is a big ass spacer on that front diff to enable using the dually rims. That way you have one spare that works anywhere on the truck.
Big Chip
Michigan
Kevin
C35
If they are actually straight and round they are worth a little bit.
Edit: Suckered into replying to an old post with this new format. I feel like a bit of an amateur right now.
twitch1989
