Factory Underside paint?
Keith Seymore
Motor City
Keith Seymore
4.3L
Not front; the wheel house (the black part) was not assembled when the fender goes through paint.
There is a front end sub assembly line after paint where the wheel inner, side trim and wheel opening trim are added to the painted fender and then conveyed to the main assembly line in sequence. The radiator support (with grill) and hood are on the same carrier.
K
eddiericks
Charlotte, NC
Edward
custom deluxe 10
4.1L
Hi Michael,
unfortunately, they are completely brown with surface rust at this point. I believe this truck has spent its entire life outside. I would imagine these areas would be touched up to a solid color (dary gray or black) prior to leaving the factory. but i cannot be certain.
Ed
Keith Seymore
Motor City
Keith Seymore
4.3L
Looking at the last photo “where did I park my truck”. My Square was built across the border in Canada and they probably had the same kind of lot.
We did occasionally lose a truck or two back in the yard. Sometimes we wouldn't find it until the end of the model year (or Christmas break) when production was stopped and the repair backlog was worked down to nothing.
By then we had already built and shipped an identical truck to replace it.
There are signals used to indicate where the truck is to go next (ie, heavy repair, paint repair, rail head for shipping): the direction the truck is pointed, hood up/hood popped, or where the repair ticket is placed (rolled up and inserted in the door handle, rolled up and smashed in the vent window, under the windshield wiper).
God forbid a young engineering student pull the ticket to look at it and put it back in the wrong spot.
K
crowe-t
New York
Michael
K
There would only be body color overspray on the rear inner wheel wells?
Keith Seymore
Motor City
Keith Seymore
4.3L
Yes - rear wheel wells and along the body side.
Not front wheel inners.
K
SS1019
St. Helens, OR
Steve
C10 SWB
My 78 is red oxide and hasn't ever been repainted, yet. So assuming it was red oxide from the factory.
dynamo969
