Factory Cruise Harness
Boone83K10
Boone, NC
Benjamin
I removed the entire factory cruise control setup from my 83 K10 Silverado.
All clips, wires, vacuum hose, speed sensor and module. I did not cut a thing. I will never use it here in the mountains and the servo nipple for vacuum from engine was broken. You can buy a new servo and I will include mine so you can get the core charge back.
The only thing I did not remove was the plungers on the brake support(since I need them for my truck). You can buy the plungers at Advance Auto part# S870P for the brakes/cruise and part# S749 for the vacuum release.
I tested the wiring before I took it out and it worked, just the servo was broke and I don't have the carb studs on my Holley. The Q-jet is long gone when the engine swap happened which is what this is for. You can probably use it with an aftermarket carb if you acquire their studs.
This is plug-n-play straight from GM.
$120 + shipping. (this is really just a guess, make an offer)
Boone83K10
Boone, NC
Benjamin
$100 shipped??????:shrug:
Like I said no idea if this is even worth anything.
Boone83K10
Boone, NC
Benjamin
Make offer :shrug:
MrMarty51
Eastern Montana
Martin
I would but there`s just NO!!!! money right now.
Jeff Dodson
Angleton, TX
Jeff
Well if he don't still have it, I have one for sale as well, but I will not jump in front of him. I will wait to here from him
Boone83K10
Boone, NC
Benjamin
Yes I still have it.
Boone83K10
Boone, NC
Benjamin
What is your zip code?
Gurn
