Engine temp and oil sensor- Noob questions
Rich77
SE Wisconsin
Rich
C10 Scottsdale
Hello All,
My truck is a '77 C10 Scottsdale Sbc400/th350.
I think I've confused myself.
Which oil pressure device do I need- an oil pressure sending unit or a oil pressure sensor?
Can I use both? Does it depend on my gauges?
Also, which temp device do I need- an engine coolant temperature sensor or a cooling temperature sending unit?
Thank you for any help!
85K304SPD
Las Cruces, NM
Richard
I think the only option to choose from is if you have a gauge or just a warning light.
fast 99
Spokane, Washington
oil pressure switch, temperature sender, sensors are for computers.
Should be able to look up the application and get correct parts. I don't work for Rock auto but after you figure out the site they have a good search engine.
88V30
