Engine code decoder
RawkerStatus
California
Angel
Suburban K20
What engine is this? I've tried searching and it doesnt tell me much.
it looks like one is just saying 5.7l SGI(might be SGC?) 5.7 is 350. casting #14093638 returns a lot of results. looks like most likely, if it came from a truck, flat-tappet cam(not sure what that is, im no expert) and 4 bolt. not a popular choice for 383 stroker because of thin decks(idk what that is) and cylinder walls
1 piece rear main seal
Im not sure on this accuracy, but
"If its got 3 (?) cast in posts in the center of the lifter valley, then its a roller block. If it came from a car, they will be machined off on top, and have threads tapped in them too. Trucks used the same blocks, but didn't use a roller cam, so the finish machine work for those wasn't done. It can be done though if you want to."
"The 14093638 tells you it's a '86 to '94 350. If the intake manifold to head bolts are all on the same plane, tell the parts guy it's a '86 Caprice. If the center four bolts manifold to head are on a different angle (canted) from the rest of the manifold to head bolts, tell the parts guy it's a '87 Caprice." Guessing a small design difference for exhaust parts
RawkerStatus
California
Angel
Suburban K20
The person who pulled it said it came out of a 96 Suburban. After looking at the 140893638 number it is pointing to a older model. The bolts are the same angle which is awesome considering i'll be able to use the stock manifold from the 86 engine.
alwaysbroken
