Electronics 101
Chris Jackson
Well - I'm no longer scratching my head.
What is the1st thing you check when dealing with vehicle electronics....FUSES
and whats the 2nd?
Go ahead ill wait..........THA FREAKIN GROUND!!!!! So after chasing every possible wire and connection, I wiggle the NEW ground cable only to find i never tightened it up.
And the moral to the story is this - always check your ground.
Totally agree.
I’ll add the suggestion that the first ground to check and tighten is the instrument panel ground. If this ground is disconnected it will cause multiple problems with the instrument panel, which makes it really hard to troubleshoot other problems.
Corvette Ed
East Tennessee
Eli
The ground can cause all kinds of weird electrical problems and it’s easy to overlook when troubleshooting.glad you found it.
78C10BigTen
pennsylvannia
C10 BIG TEN
Im thinking thats my problem on my s10. Gauge lights are super dim, gas gauge only partially works and the other gauges are wonky.
Chris Jackson
Lol a loose ground will make you feel real dumb!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Is your s10 VFD or the analog display?
If its VFD, its not a ground my friend.....
78C10BigTen
pennsylvannia
C10 BIG TEN
Not sure what vfd is but im betting its analog. Its a 91'
So will a loose power wire, or locking your keys in the car .I guess we could keep going but nah.
twzorek
