Electrical wiring for the k5ton
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
This must be what you gentlemen are referring to
Sent from my SM-G965U using Tapatalk
Vbb199
Salisbury NC
Vince
Would either of you gentlemen know what these go to? I can't seem to locate them behind the dash on my suburban.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
those are for the ignition switch.
For what you are trying to do, I would suggest a service manual or some detailed wiring diagrams. Enlarge them as much as you can and still have them legible. Things like headlight, taillight, etc have been the same color for about the last 40 years. However, the pinout location in the connectors to change. And when it comes tome to make your splices, do yourself a favor and try to keep the factory wire colors. It will make things much easier
Vbb199
Salisbury NC
Vince
I appreciate it, I have a manual, and wiring diagram for my 90 Subruban, I'm kinda going back and forth between the k5 and the suburban trying to figure it all out, I looked all under the dash, couldn't seem to find those wires anywhere or plugs on the k5 for them, I've just about wrapped up the interior.
Vbb199
Salisbury NC
Vince
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The ignition switch is on top of the column, it’s kinda hard to see when it’s all bolted in place.
Vbb199
Salisbury NC
Vince
Ohhh excellent. I'll look into it tomorrow. That just about wraps it all up for the inside of the truck there's 3 more wire bulkheads I'm unsure of, one of them is the radio wires, I'm not 100% about the other 2
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
GM was polite enough not to change wire color function year to year like other automakers. Orange has been hot at all times, pink is ignition hot, brown has been parklamps, etc since about the early 60s until the last few years the new CANBUS systems in cars today gas unfortunately changed all that. Take a couple pics of your connectors in question, I’m sure someone can help
Vbb199
Salisbury NC
Vince
I'll snap them tomorrow, once I get those answered, I should be done.
Vbb199
Salisbury NC
Vince
Last 3 wires, if someone can help me with those I think I'm gonna be good on the interior
3rd wire comes out of the steering column.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The one on the left with 4 wires is stereo, the yellow wire is ignition on power, gray is dash lights, brown is parking lamp feed (dims the radio lights with the headlights on) and black is ground. The 2 pin clear connector looks like it would go on the brake switch. Pink/black is key on power, the other wire appears to be purple? Maybe the brake switch for the torque converter clutch? The 3rd connector isn’t a factory connector, are there any non stock add-ons? Maybe a aftermarket radio?
Vbb199
Salisbury NC
Vince
So the first plug is for the radio?
If so good, that solves that.
My thoughts was the middle connector was for the brake switch, but those pins on the back of it are spaced closer together. I couldn't seem to find anything that went to the back of the brake switch. Just the main plug that, goes on the bottom of it. It's pink and brown.
Third plug I didn't recognize as a GM plug. It looks like a plug that would go into a computer device (hdd, CD drive etc)
It's ran up under the plastic, almost directly in line with the key ignition.
That middle one may be for Cruise Control Release. That switch is right next to the brake switch.
Vbb199
Salisbury NC
Vince
Great, then it won't need it either lol, I just want to make sure I get the essentials working right
Neimough
Western Pennsylvania
Ron
K5 Blazer
I'm showing 2 grays and a gray/black for the cruise control brake release in the 82 schematic I have on hand... I've been digging through my schematics to find a brake switch with a pink/black and purple or brown but I've had no luck. I show a purple circuit -6 going to a clutch start interlock. There's also a purple circuit -92 going to the wiper washer switch. And another purple circuit -16 going to what looks like the hazard flasher. That pic is hard to see the color with the pink/black. I have a lot of schematics from when I rewired my Blazer.
Vbb199
Salisbury NC
Vince
A little better?
Yellow grey and black on the first connector
Pink/black and purple on the second connector.
rickybobby69
