- May 18, 2020
- Washington
- Todd
- K20
So maybe this should go in the efi or engine section but figured more views here….
Truck in sig. Carbureted engine with electric fuel pump and no option for a mechanical pump. (It was originally an EFI Vortec )
Currently ( no pun intended), electric fuel pump relay is triggered by a random ignition on hot lead. Works fine, except it’s not dummy proof in that if you sit with key on engine not running, fuel pump runs continuously.
Is there some sort of pressure sensor or timed relay to emulate efi engines where the fuel pump primes at key on and then does not run until cranking or running rpms are observed?
Or any suggestions on how to wire the fuel pump to run only while engine cranking or running?
