- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
You have to set the choke first, then press the pedal. If you do it the other way, the carb isn't setting onto the high idle cam or properly setting the choke.xc_hide_links_from_guests_guests_error_hide_mediaHere’s a cold start of the truck this morning I press gas once and then pulled choke and after it fired I tried to push it back in, Hugh idle is usually 1100-1200 but it only got up to 800ish in the video I think. Usually I pull the choke after I got it started though. Any ideas how to get it to move easier? Lower the high idle screw?
