Dually rear leaf spring question
charlesg
wisconsin
charles
k3500
So I want to take three of the bottom leafs out of my truck to lower it a lil and soften up the lumber wagon ride I have now, what will this affect??
Shouldn't change much besides ride height and load capacity. How many leaves are in your pack?
charlesg
wisconsin
charles
k3500
six with that big thick over load bar on the bottom
Hmm that's kind of odd I think. Most 1-ton's had 8 leaves or more, at least that I've seen.
Either way, if you don't pull or load much weight, losing a few leaves shouldn't matter.
charlesg
wisconsin
charles
k3500
I took two out of the bottom already..l.
Either way, if you don't pull or load much weight, losing a few leaves shouldn't matter.[/QUO
Derrick Taylor
550 Albion Ave, Schaumburg, IL 60193
Derrick
c30
Mine had 8 or 9 leaves, I removed the bottom thick one and then every other one after that. It lowered the truck 2 - 3 inches and definitely improved the ride.
Derrick Taylor
Derrick
c30
charlesg
wisconsin
charles
k3500
Any pics? isn't that thick one to keep from breaking springs?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
The bottom overload doesn't prevent breakage. When I pulled mine out to have them rebuilt the #8 leaf was broken on this one and the #7 on the other.
charlesg
wisconsin
charles
k3500
what is that bottom flat one for then?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
The bottom is the factory overload. It gives the rest of the spring pack a base to rest on to give the full capacity of the spring. The top spring is the secondary over load. Once you get enough weight in the truck it contacts the tabs on the frame.
I removed one of the lower leafs in my pack during the rebuild to give a little softer ride knowing I had the top leaf if I ever loaded the truck down heavy.
90sBurb
