Dual Tank Valve Ground
Ronno6
South Mississippi
Ron
Seems like a simple question:
1984 C-10 gas engine.
How is the dual tank switching valve grounded??
Only thing I can see is that the valve is grounded thru the gauge sending unit??
Doesn't make much sense to me.
But I have pored over the schematics ans I can see NO ground wire anywhere.....
When testing the power to the plug, I can get a 12v reading between one green wire and ground
when the switch is pushed in one direction, but can only read about 6v on the other green wire when the switch is pushed in the other direction....
Or, do the 2 green wires supply power and ground, but reverse polarity when the switch operation is reversed??
Stumped......
SirRobyn0
So the switch changes polarity. IIRC there are 2 wires that actually operate the switch, the rest of the wires are for the gauge. The dash switch changes the polarity of the switch wires. Where the actual ground is I don't know.
Ronno6
South Mississippi
Ron
Be that the case, then for one tank, one green wire is 12v + and the other is ground, then they swap for the other tank position of the switch... I will check that out.
But, if true, I should be able to read 12v from one green to ground when switch is pushed up, and between the other green wire to ground when pushed the other way.
I do not have those readings...
Ronno6
South Mississippi
Ron
You are correct.
I was able to see +12v at the harness when the switch was pressed up, then -12v when pushed down.
But, then the voltage went wacky...like 3 to 4v...each direction. I did hot wire the valve and it moves in both directions.....a good thing. Just not when I try with the switch. Actually it DID move...once, but nevermore... But, maybe I should replace the switch and the valve as long as I have them out ??
SirRobyn0
You are correct.
Honestly that sounds like a switch problem to me as well, but given the importance of a properly functional tank switch, yes I would opt to replace them both.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Can't over stress the importance of a good ground for the switch, the valve, and the fuel pumps.
Lowered87
Oxbow, Saskatchewan
Adam
R10
Lowered87
Oxbow, Saskatchewan
Adam
R10
Just remember there are different switches depending on the year of your truck. Also the big black wire off of the sending unit needs t be grounded to the frame.
SirRobyn0
This is a pretty old thread, but yes the switches are different and they work quite differently and are not interchangeable at all.
ali_c20
Austria
Alexander
C20, K5
If you're replacing the valve the switch must match the valve.
Dons79C10
