84-C20
- Dec 6, 2019
- Chevrolet
Update: Well at this point I can firmly say that this is some sort of balance issue as the screw clamps have made improvements if nothing less. This morning I took the clamp by the transmission off and drove it to work. The vibration was obviously worse than last night with the clamp. At lunch today I put two clamps on in the same spot on the upper shaft, drove it, wasn't happy, spread the clamps about 35 - 40 degrees apart, drove it and it felt like the best it has been so far. But now I feel I can feel some vibration from behind me so I put the clamp on the back shaft in the position I marked and it is now the best it has been so far. I'm not saying it's as good as a driveline shop could get it, but it's definitely much improved. I have to make a short freeway run tonight and I'll get a good run at various speeds in varying terrain so I should have a better idea where I'm at after tonight.
