Driver’s door decals
tj43
Little Rock
TJ
V1500
Does anyone know if these missing decals were OEM and, if so, where I might find replacements?
Thanks in advance.
fast 99
Spokane, Washington
Those appear to have been oil change stickers. Gas stations commonly used them.
tj43
Little Rock
TJ
V1500
Thanks. I was curious if they might have been maintenance stickers. Glad to confirm they weren't OEM and I can clean the old adhesive off without guilt.
The Right side of Washington
The lower ones, yes.
Upper one (s) are factory. But idk what the missing one is is both of our pics.
tj43
Little Rock
TJ
V1500
Thanks. Exactly what I needed to know. Any idea if/where I can get a re-make for an 1988 Suburban V10?
Off the top of my head, no. But I’ve seen somewhere where repro decals for under hood and even the spid sheets are available.
Maybe do some searching here or classic car parts houses like LMC.
And someone more knowledgeable than me will likely have better info for you in your thread here I’d bet.
WRW86
Alberta, Canada
Warren
K2500
The lower one should look like this other GVWR decal:
WRW86
Alberta, Canada
Warren
K2500
Does anyone have a photo of the Tire and Rim information sticker for a K2500 with a 6600 GVWR? Mine is gone too, and curious what it would say for the improved ride section with only 3 passengers, etc.
Looks like all the same info as the top sticker? But you’re totally right based on the outlines of the sticker in my photo.
There’s an improved ride section?
If you’re looking to improve the ride there is really only 2 distinct things you can do.
First, run the proper min pressure for the load. If you’ve got an empty truck, you’re looking at 25-35psi rear max depending on tire size. And 35-50 front. Again small tires = more air and vice versa.
After that it’s swap to lighter duty and more compliant springs.
legopnuematic
Licensed Junk Dealer
MO
Spencer
look at the lower section of your door sticker-
He is looking for one for a 6600lb K20, instead of an 8600lb GVWR K20
Ha! Well I’m blind! Stands to reason as I’m not certain I’ve ever stared at any gvw sticker in particular.
Wonder if the lower gvw trucks have it as well?
Regardless, the info I provided to @WRW86 is what to look at for a softer ride.
Thanks man!
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Thanks in advance.
This is what is left of mine.
Moderator
That bottom one might have been camper loading information?
WRW86
Alberta, Canada
Warren
K2500
I don't think they put the camper information on the door, but mine is inside the glovebox beside the SPID.
Here is what the camper decal looks like:
Original
