Toad455
- Aug 3, 2023
- North Texas
- Kevin
- C10
I'm doing final block sanding on my 78 cab. I rebuilt the door hinges with oversize bushings and I have the door gaps exactly where I want them to stay. I used filler rod/bodywork to get the gaps better than the factory ever did on these. I really don't want to remove the doors but I need to so I can paint it the way I want to, inside the jambs, etc. I see info on how some people drill holes and use pins but has anyone on here done this before on one of these trucks? I plan on leaving the hinges bolted to the cab and drill/pin the hinge at the door. (but maybe at the cab would be better?) It was a real pain to get the gaps where they're at. I also thought about drill/tap holes and use bolts to hold in place for reinstall but I would prob drill into the nut plate which floats. Has anyone done this or something similar?
