Distributor
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
1986 GMC sierra classic 1500 SWB 4x4
305” on a 700r4
I have bypassed the ESC & removed it. I also bought a new distributor.
My question is;
“Did I buy the wrong new distributor?”
is there a difference between an ESC distributor and non-ESC distributor?
I know i can just jump the two wires that I connected on the other distributor, but one less jury rigged thing, would be nice.
My new distributor has the vacuum advance canister on the side. I took it out of the box so I don’t think I can easily return it, but if there is another distributor that would be more proper, I might just try and exchange it.
Jwernatl
Senoia, GA
5.7ltr
What part#'s did you buy?
BJedi76
Soldotna, Alaska
B.J.
305”
How will pictures help?
I bought the distributor that goes to a 1986 GMC with a 305, from the store.
there weren’t options.
My question refered to whether I should’ve purchased an older distributor that has different wiring. One that go to a truck without ESC.
…and if so, which one is that. As in, what year(s)?
BJedi76
Soldotna, Alaska
B.J.
305”
BJedi76
Soldotna, Alaska
B.J.
305”
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Just bought a new distributor from OReilly that I modified for a pre-oiler. So, have new cap and rotor if you need one. I am over here on East Mackey Lake.
BJedi76
Soldotna, Alaska
B.J.
305”
Please forgive my ignorance, but what does pre-oiler, mean?
AKguy
Alaska
Randy
Prior to starting a new/rebuilt engine, oil needs to be circulated under pressure to ensure you are getting flow through the system. Typically, a pressurized oil tank attached to a port, or a tool is used to spin the oil pump to circulate the oil until you have pressure and a visual of oil coming up through the pushrods. The tool I was using initially to spin the oil pump did not appear to have the correct lower profile to ensure I had flow. Once I got the new distributor and modified it to spin with my drill, I got the flow confirmation.
BJedi76
Soldotna, Alaska
B.J.
305”
I’m not sure I understand.
Did they, luckily, give me the wrong distributor?
there were no options.
1986 there was definitely an ESC, which I had, until I removed it.
weird…
BJedi76
Soldotna, Alaska
B.J.
305”
The vacuum canister on the new distributor, is much bigger and it hits (what I assume is) the engine lift loop bracket.
lol… The tragic part is that it only hits the bracket at exactly 4°.
I guess I’ll just have to remove the bracket. I thought about just bending it down, but that’s a pretty thick bracket and I don’t want to pull that hard on an intake manifold bolt.
I don’t know if the bolt is longer to a accommodate the bracket or not, but I suppose if it is, I can just use a fat washer to take up the space.
i’m still a little tripped out that they accidentally gave me the wrong distributor, which is the one I needed. Lol…
