Distributor replacement
Manswame
Alaska
Sarah
Anyone have a good video on doing a distributor replacement. I've never done one and would like to see it before I attempt.
Mostly how to mark the rotor position during removal. The shop manual says the pull up then rotate it CCW and remove it. Does that mean you mark where it sits when it's attached, lift it until it stops, then rotate it until it comes out. Then to reinstall a new one you put it in the position it was when removed then twist it back into the position it was in when installed?
Yeah a video would be nice lol.
Sent from my Pixel using Tapatalk
twzorek
