diesel tach
RalphG
landers
Ralph
6.5 turbo diesel
i have a 87 square body instrument cluster, i want to add a factory tach. my problem is i have a 6.5 diesel and i need to know is the gas tach is the same as the diesel. i have located the gas tachs but no diesel.
Rickf
Grafton NH
1974, 1954 & a 1937
You might be able to get a gas tach to work on a 6.5. If you put a HEI where the vacuum pump goes and run an ignition+ wire, then you'll have a tach signal to run to the gauge cluster. Of course you'll be missing a vac pump. I had an aftermarket diesel tach that had a pick up hose clamped to the alternator, might be an easier way to go.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Look at Chevy C60 and C70's. They have the 4k and 5K tachs. The upper is the diesel as it has the 150 LBS air pressure gauge.
dvdswan
Port Orchard, WA
Dave
I've got a (2actually) diesel tach with fuel gauge in it. Both are 4K RPMs. LMK
eskimomann209
Modesto
Marcus
Sooo like wanna sell me one
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Top is diesel, bottom is gas.
dvdswan
Port Orchard, WA
Dave
Shoot me a PM with your price you think is fair plus shipping. If you want I can throw in a vacuum gauge as well. I don't have the cluster anymore, just the gauges.
