Diagnostic port problem
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Hey everyone,
Truck is a 87 V10 TBI 350
Diagnostic port as no power. Anybody have this problem? Possible causes?
As far as I know it never had power. Truck was throwing a code and went to have it tested and the truck wasn't even detected.
Sent from my XT901 using Tapatalk
Where did you take it to have it scanned? They just didn't know what they were doing. When hooking up a scanner to an old OBD1 port, there's a power wire that plugs into the adapter, then the power wire either clips to the battery or plugs into the cig lighter. They just forgot to hook up the power wire since OBD2 (probably all they ever hook to) plugs don't need the extra hookup.
You can check codes yourself though, with a paperclip. Just jump the A and B terminals and turn on your ignition. The SES light will flash and you just count the flashes. It will always start off one flash and two flashes then it will pause and do that two more times, that is code 12. It will then follow with whatever codes are stored and displays each code 3 times before moving to the next. It finishes with code 12 again.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
I took it to O'Reillys. I was told obd1 doesn't store its codes. Main reason I am asking is because I'm trying to get power to it so I can plug it in to a computer and be able to see what my engine is doing at all times.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Alright thanks. The cable doesn't have the power adapter like bucket said. Is it necessary?
robert8096
Goose Creek SC
Robert
Don't think so. The only thing that needs power is whatever is collecting the data. I just use the paper clip method to retrieve the codes.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Yup, use the paperclip. ALDL cables are good for deeper diagnosics, where you can sorta use the ECM as an engine analyzer.
There is not power at the connector. If the equipment does not work because it says "no power detected", then it is not properly hooked up and needs 12 volts plugged into it. The worker at Oriely's has probably never hooked up to OBD 1 before, just OBD 2 that is supposed to have power at the connector.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
Oh alright thanks. Is it normal to throw a code light comes on and then goes off after a while? Every vehicle I have that threw codes it stayed on.
Yeah it happens. Were you the one that said your truck doesn't have an O2 sensor?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
No. I'm not sure if it does or not. The previous owner cut the exhaust off at the cat. When I get underneath I never really looked but I can take a peek at it tomorrow
Sent from my KFTT using Tapatalk
88V30
