Dead positrac...
JEM
Union Bridge, MD
Joel
So the shop that is re-gearing my axles just called and said the positrac in my 14 bolt was about dead and any offroad use could kill it. Do ya'll have any recomendations for a something to replace it? thanks.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I think Greasedog has a 14-bolt Detroit locker on here in the for sale section cheap!! :cheers:
JEM
Union Bridge, MD
Joel
Mines a semi floater
crazy4offroad
Curt
K-10
350/SM465/NP205
Dang. If you'r not pushing a lot of horsepower you could go for a Yukon or Lock-Right.
JEM
Union Bridge, MD
Joel
its a stock jasper 350 and i dont plan on building it up much other than carb and manifold.
JEM
Union Bridge, MD
Joel
would that lockright work for 35" tires and the 37" i eventually want?
crazy4offroad
Curt
K-10
350/SM465/NP205
That may be pushing it a little. They are slip-in style, meaning your spider gears and side gears come out and the parts for the locker go in their place. This means a majority of the stress is on the crosspin. You may want to consider a full carrier style locker or posi which will require new bearings and the ring & pinion set up again.
http://completeoffroad.com/i-124178-detroit-locker-gm-14-bolt-9-5-det225c-135a.html
JEM
Union Bridge, MD
Joel
The shop said that if i wanted them to get it they would get an auborn(?) locker
crazy4offroad
Curt
K-10
350/SM465/NP205
That's a good one. Auburn, Detroit, ARB and Eaton are to tier brands. Hope they dont try to get you for full retail price on it though. And expect there to be additional charges for R&P setup.
JEM
Union Bridge, MD
Joel
He said it was around $580. And i believe that there will be no extra installation charge because hes already doing gears but i am not sure. My problem is im trying to get this done before i leave for boot and I'm running short on money.
crazy4offroad
Curt
K-10
350/SM465/NP205
Well that sounds like a good deal then. Most I see are above $600.
JEM
Union Bridge, MD
Joel
Would you have brand you would recomend for an 8 inch lift kit?
crazy4offroad
Curt
K-10
350/SM465/NP205
Amount of lift has nothing to do with it. Tire size, gear ratio and engine horsepower however does. Honestly any of the full-carrier styles will work great for what you're doing. 35" tires is the borderline for slip-in style lockers and posi's.
JEM
Union Bridge, MD
Joel
Yeah i understand that. I'm just trying to get an 8 inch lift kit as well and i thought id ask the question.
JOD26
