Dead cylinder #5
joejw 1982
Ct
Joe
5.3 vortec LS
What would cause a dead cylinder only 1 after warm up I've replaced plugs wires coils cam sensor cleaned crank sensor checked push rods springs and rockers
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Cam/crank sensor ? :eek: On a 1982 ?
Oh, BTW - I think that PDF is not square related. :cool:
Check compression.
Edit. Didn't look at the picture just read the text.
Tennessee
Im gonna say your compression for that cylinder is good looking at your picture. LS engine in the same picture I would look at the injector. Swap it for another and see if it goes to the cylinder you swap it to.
joejw 1982
Ct
Joe
5.3 vortec LS
I did move it around and it stayed in #5
joejw 1982
Ct
Joe
5.3 vortec LS
U did it's holding at 150
Sad Sack
Nebraska
Goober
C15
ECU?
Also is the electrical signal even getting to the injector?
Read this thread:
Isn't 150 a good number for compression? Definitely not dead
I wasn't looking at the picture,just the text,I've done this and this and this. But wasn't thinking I needed to look at a picture too.
Make a noid light. A piece of speaker wire,2 t pins 2 leds,wire 1 led in each polarity use the t pins to back probe the injector connector,see if signal drops out while running. Mine is extra long so I can put it under the wiper and watch while driveng. Put a timing light on #5 see if spark drops out hot. Also did this engine originally have AFM?
GRat
