Dash bezel interchange
1984dually
Malin OR
Danny
C30
8.1L
Going to repair the radio hole that was cut out on my 84. Getting a 78ish truck that is rusted and not worth fixing. Pretty sure the dash bezel is the same from 73-87 but would like some conformation on that. Thanks
WebMonkey
Missouri Ozarks
check the headlight switch area.
wiper switch in the dash vs on the turn signal stalk.
check for a/c vent in the bezel vs no a/c vent.
good luck!
legopnuematic
Licensed Junk Dealer
MO
Spencer
84 should have column mounted wiper and headlight controls, a 78 will have dash mounted wiper switch and headlight switch. the bezels are a slightly different profile i believe to accommodate the changes to the 81-87 dash pad design
RoryH19
Rory
R10 Silverado SWB
Right, there is a difference. As mentioned above wiper will be on the dash before 84 and the over shape. 81+ has a "smooth" face while the earlier ones have 3 sections.
Try to fine one on CL.
Yes, they have a different profile based on the style of pad. I had good pictures of the differences, but I think I lost them on my old phone.
1984dually
Malin OR
Danny
C30
8.1L
Thanks for the information. Guess I’ll find a correct one. Still a lot of parts to use on the truck.
Super-Dave
Dave
I wanted to preserve my OEM dash bezel on my '74 build, so I bought another " '74 " off Ebay. I reworked the gauge holes to accept my Speedhut gauges and had it hydro-dipped in Red/Black Carbon Fiber. When I went to install it, I discovered that the light hole was huge (on my OEM the light knob come out of a small hole in a raised pyramid shape) and the hole for the wiper slider was wider and offset to the right - real close to the bend in the bezel.
Essentially, the Ebay dash bezel was unusable in my application and it's going to be sold.
I made the mistake of assuming the seller's description was accurate and that '73-'87 actually means everything in that year range will fit. IT DOESN'T. All it means is that the mounting screws will line up. . . sort of. I also made the mistake of not comparing the two bezels before doing the work, as it was 90 miles away at the time. My Ebay bezel is clearly a later '70s version.
It seems that there are a lot of one-off's in the '73-'74 years that makes the '73-'87 designation misleading on many, many parts when you own a '73-'74.
That's a '75-'77 bezel if you are still curious.
Turbo4whl
Downingtown, PA
Wayne
@Super-Dave
Dash pad looks wild! I like it. I have seen stuff like this but I did not know you could coat original plastic that way. Who does this kind of stuff?
Turbo4whl
Downingtown, PA
Wayne
My '82 dash bezel has the headlight hole like that, but I believe the upper part is different to match the different dash pad.
@Super-Dave
Could you just fit the later headlight switch to your early metal dash and still use the custom hydro-dipped bezel?
@Super-Dave
Yeah, the headlight hole is like that through '83, but the wiper switch hole changed slightly for '78. That one is '75-'77 based off of the wiper hole and also the contour of the face around the gauges. Starting in '78, the face was divided into different sections with a raised edge bordering the different sections.
Bhardiman1
