Dana 60 hubcaps.
chevyguy76
Maquoketa iowa
Ed
M1009
Hey guys, I’ve done some searching but can’t seem to find any current listings for the factory Dana 60 hub caps. I have a couple pairs of fronts. Driver quality that I might sell. Just trying to see what they were going for.
The Right side of Washington
Well “driver quality” could mean many things. But those are the hardest to find (also least in demand as there are far more 1/2 and 3/4 ton trucks out there looking for OE hubcaps.
As usual, price them a bit high and see what happens.
If no dents in them I’d bet they fetch $40 a piece or more.
SquareRoot
Can you post a pic? Also, check you mailbox, I sent you a message.
85K304SPD
Las Cruces, NM
Richard
Throw up some pictures of them, and see what you find out. My K30 has a Dana...Hmmm.
Big Chip
Michigan
Kevin
C35
One post in 12 years?!? This has to be some sort of record.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thats all the ones I have. Got enough for a c25 gmc, a k20 gmc, or a k20 chevy, and half a half ton gmc, haha
What do these Dana 60 caps look like? I'm unfamiliar.
Strick
Dunn, NC
Harold
C20 Crew
Don't they all have 2 rings on the inside so the center an be cut out for either 44/10 Bolt or Dana 60? That's how mine are.
Strickland
Bennyt
Surprise
Ben
They have a deeper lip and I believe a larger diameter knockout than a 3/4 ton hubcap with a 10 bolt or D44 axle.
Why does this pic remind me of a girlfriend I once had??? And yes, they were larger diameter and she had deep lips as well.
SquareRoot
Strickland
No
Craig 85
Nashville, TN
454/TH-400/NP205
Yes the D60 hub caps have a larger inner diameter.
For reference with aftermarket wheels the one on the top is a GM 10 bolt. The bottom is a D60. You can see it fills the cap completely and protrudes further.
Strick
Dunn, NC
Harold
C20 Crew
There are two trace rings on the inside of the wheel cover to accommodate both the smaller and larger hub though. I only have the 10Bolt/Dana 44 pic listed here. These are much more common than the larger Dana 60.
Strickland
Rumbledawg
the back 40
K30 crewcab
niiiice!
would love to get a set in good shape as them
NateP350
