CUCV with rear disc - no park brake?
Chris825
Florida
Cummins 4BT
Hello all - I have a square body with CUCV front and rear axles under it. The rear has disc brakes and I am learning that these must be a bolt on conversion? The trucks original parking brake cable is rolled up and not being used. I have looked where to connect it and am finding nothing. Just wondering if the experts on here can help be confirm that these must be a bolt on kit and no parking brake is available.
if this is the case, can anyone recommend something I may try, are those drive line parking brakes worth trying? It does have a divorced np205 transfer case if that helps any with options to try.
Attached are a few pictures, I may need to provide some with the wheels off…
RoryH19
Rory
R10 Silverado SWB
Yes, someone converted to rear disk at some point.
You can swap the calipers for the 70s Cadillac ones. They have a lever that will connect to the original ebrake setup.
Try this site for more info.
Chris825
Florida
Cummins 4BT
Thank you sir — this is exactly what I am looking for!
nvrenuf
Mobile, Al.
Are you sure it’s a cucv? They never had a divorced tcase and only a very few special models had a married 205.
Just saying in case something misinformed you about your truck.
Chris825
Florida
Cummins 4BT
The NP is original from the 1985 Chevy, it has a Cummins 4BT in it with an Allison transmission. The transfer case has been divorced with twin sticks etc. I mentioned it incase there was a gadget out there for a parking brake that attaches to the transfer case…
Lugnut 4x4 has the exact kit I need for the Dana 60 rear end, already have it in the shopping cart. I’ll post a follow up with pictures once it is in place.
Original
