GOBR
- Jan 24, 2012
- Memphis
- David
- R10
Well I got the other motor put in. I wish I woulda known it had a small knock before hand.......... Grrrrrrrrrrrrrrrrrrrr
Its got a blown head gasket and I guess the guy drove the other truck with water in the oil and it messed up some bearings. Its got good oil pressure but when it warms up it drops real low. Like at idle between 3-5 psi. I havent changed the oil yet. Im puttin on the head gaskets tomorrow and then Ill change the oil. Ive got some 10w30.
After the oil change do you think it will be ok for a little while if I keep the rpm's low?
Also I have a 2wd and was wondering if its possible to change the crank out without pulling the engine. Im bout tired of messin with this thing and sell it............
