Correcting uneven suspension
Carb'ed Vortec 350
I was going to suggest different spring rates even though they were new. Then they were actually different height, perhaps different rate as well. Hopefully the new one correct it.
mattsk8
Michigan
They're actually sending me a new pair :oops:. I think the lower one was bad, and it was a combination of height and spring rate.
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
If you needed 1/2" of shim to get it level and the spring was only short by 3/16", you're still going to have a problem. I don't think you've solved it.
Moderator
That was 3/16" with it unloaded. The difference when loaded could have been greater. Also, any given amount at the spring will be a little greater at the wheel.
mattsk8
Michigan
Just got back from vacation and they sent me the wrong springs, they sent springs for a 72 body :banghead: . Can't call until tomorrow.
mattsk8
Michigan
My springs should be to me tomorrow, and hopefully they're the correct springs this time. But it occurred to me that I have the HD ORD bushings in my springs, which IIRC have bigger holes so I have to use the ORD bushings now. I haven't tried yet, I will tonight, but has anyone successfully removed the bushings from the springs? Or should I not even try and just order a new set of the rubber bushings from ORD?
Edit: I might be OK. I just looked up the ORD bushings and they aren't necessarily HD, just greaseable with kevlar bushings. Skyjacker sent me new bushings for the wrong springs they sent, they did not send new bushings for the correct springs I should be getting tomorrow (I know, this is getting confusing lol). But, looking at ORD's site, the bushings appear to be the same for 67-91 Chevy Skyjacker springs, so the bushings they sent me for the wrong springs should work in the springs I'll hopefully be getting tomorrow. Fingers crossed...
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
UH OK???!!!
Moderator
The newer ones are some fancy Kevlar material, but the older ones are not. Iirc, the rear bushing bolt increased in size in '87/'88 and that's the size ORD uses with their bushings and HD shackles. This is just off memory, so I could be incorrect.
mattsk8
Michigan
Thanks. I was worried for nothing, the bushings popped right out
mattsk8
Michigan
New springs made a HUGE difference. It was 3/4", now it's roughly 3/16". Also sand blasted and painted the front diff while I had it out. Grenading the diff sucked, but in the end I now have a TrueTrac and my truck doesn't sit like it has a flat tire anymore. Calling it a win :cool:
Shorty81
Baby Boomer
North West ohio
Darren
awesome color by the way....
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
^^^^^^^^Nice eye @bucket .....which one did you use???.....lol...^^^^^^^
mattsk8
Michigan
Haha, it's actually Toyota Inferno, IIRC it was a 2016 color. My camera is terrible at catching it under my LED shop lights, in the son it's a shade more red with a good bit of metallic.
dudleyrushmore
