complete 1984 4.1L inline 6 Brighton, IL 62012
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
One of my So Cali buds did. Check out the license plate.
That's cool but it isn't a a BAT car. (Big Ass Turbo)
That's a 13.10 dialed in car, and he breaks out occasionally in the right conditions and he has had it just under 13 a few times. All naturally aspirated, No boost whatsoever.
I wouldn't mind either. I've always been against N2O. In fact, I had stickers made. But I wouldn't mind trying a real nice 88mm or 98mm Turbo. However, things have changed, cam science has improved, technology has improved, I think I would even play with a small adjustable N20 wet kit too.
Like my Photoshop job on that sticker? Baby bottle nipple instead of the valve. My skills weren't good enough to put the red circle with the line through it like No smoking signs which is what I wanted to do, but had to settle for the black X.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
A nice 88mm would look especially nice hanging off one of those.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I looks good. I thought of spraying mine with a 100 shot.
But, let's not get to far off track here, but there you go folks, I6's can run, and it appears zieg85 is paring his out now.
Did you get good money out of that exhaust manifold Carl? That HEI Dizzy complete I'd think should bring at least $25. If you know for a fact that integral head isn't cracked, that alone could be a Benji and they love to crack so someone may very well be looking for that head. However, most people just find a decent used V8 instead of dealing with cracked integral heads anymore, so a $50-$75 price might entice someone on CL to pick it up. As said I wish I was closer and had some cash. I'd have no issue running an I6 in my K10/20 truck, but I'd want to find a 230 NON integral, NON emission head for it. For a trail truck you don't need a ton of horsepower. You need the torque and the money is better spent on gear and traction accessories like lockers in a 4x4.
One of the big tricks to make an I6 run good, is the head bolt bosses that go down through the top of the head and through the ports, is you grind out the bolt bosses, stud your block on the manifold side with short studs, then use crows feet and torque the nuts on the studs in the ports before you put your manifolds on. By doing so you knocked out a **** of restriction in the ports and that head breathes much better. Think about how much meat and restriction you're taking out of those ports.
Right, but if willing to spend the money to do, may as well step up a little and get the carb spray plate is adjustable from like a 100-300. IIRC, that's even a 2 solenoid plate so you can make it a wet plate. 1 solenoid for the N20, and then another solenoid for either high octane race gas or maybe even E-85 from a separate fuel cell that will only be drawn from when N20 is activated at WOT.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
See we are on the same page, but where I want to run it no N2O allowed and I'm not hauling 3-4 hours to run in a street class.
Wow, that's a track that is No N20 allowed? I guess they don't like the fires. :happy175: But still, you could have the plate installed. Just unhook the braided line and cap it off for inspection to run on the track.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yup.
Affende
ColoRADo
Affende
83 and 84
C1500 and K3500 3+3
250 and 454
Let me check on my 83 ... i know one of my brackets is broken and ill get back to you.
zieg85
Brighton, IL
Carl
7.4L
anyone need anything off this engine, going to toss it out in the barn if not
Damn that sucks. Friggin distance kills so many deals.
Have you listed it on Craigslist? It was a running engine right?
david b
