Color code rear step bumper
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Of course it could have been ordered with it, built w/o and then put on afterwards, but that is not too realistic, is it?
BIG sidebar:
Oddly enough - that happened with my '65 GTO.
It was ordered with the tach/rally cluster (RPO 504) but was built without. No idea why.
We stuck a Sun tach on the column after we got it home, which is still on there.
Modifications to an order that occur before the build sheet is broadcast are captured in typeface; modifications after the build sheet is published are captured in pencil.
K
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Geez. I just thought of an even better story (closer to home):
I ordered my '87 just like my dad and I always did: six cylinder, manual trans, manual windows, manual locks, rubber floor mat. But I added a few trinkets to make it more pleasant, like power steering, power brakes and (later) A/C.
I also wanted cruise control and the gages/tach cluster.
The problem was - my truck got placed on stop order.
Long version here:
Short version is that when it came off stop order the engineering specifications people forgot to show that cruise and the tach could be available with the MY6 trans. So I had to change the order to delete those so it could get built.
After I got it home (around this time of year in 1986) I procured a tach cluster over the counter and installed it. For the cruise update I ordered a dealer kit, which included everything required, and put that on myself.
So - ordered with cruise control and tach cluster - built without - put on immediately afterwards.
K
Sad Sack
Nebraska
Goober
C15
amazing, the color in the exact code 521 is available. I hope it is the right or I´ll have to paint the whole bumper to keep it decent. may be I have to anyway as there sure enough is aging to compensate
Or paint them both...;)
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
I'd take the bumper off clean it, prep it, and paint the whole thing.
elbpony
Germany
Tim
C10 Custom Fleetside
350cui 4BBL
Long version here:
Short version is that when it came off stop order the engineering specifications people forgot to show that cruise and the tach could be available with the MY6 trans. So I had to change the order to delete those in order for it to get built.
So - ordered with cruise control and tach cluster - built without - added after the fact.
K
Crazy how anything can really happen. Well, who knows the truth bout my bumper, it at least fits the picture
The Right side of Washington
I am reluctant but will in the end probably do that
Why the reluctance? We’ve probably spent more time discussing it in this thread than it would take to get ready to paint. And whether it was argent colored originally or not, or installed at the factory or not, white looks better and matches your truck with the base model white bumper and mirrors.
Sad Sack
Nebraska
Goober
C15
When in doubt, spray them both.
elbpony
Germany
Tim
350cui 4BBL
Because I am a man of office work if you know what I mean...
Fair enough. Then this is the perfect starter project. Few bolts, couple wires, no fancy tools or equipment or knowledge needed. and you can get a great looking paint job on a bumper like that with just some good rattle can paint!
elbpony
Germany
Tim
350cui 4BBL
Well gentlemen, somewhen I will find the guts to start that path
duncan_schawalder
