Cluster Swap
Ty Garvin
Summerville, South Carolina
Ty
I have a 87 V10 with the "No gauge" printed circuit. I tried swapping it out with a entirely new cluster and every gauge went the opposite way when I turned the key. Is there anyway to put factory gauge in without rewiring?
Ty Garvin
Ty
Bottom is the original cluster for my truck. Top is what I want to put in.
Moderator
The connector needs re-pinned in the correct order and the appropriate oil and temp senders need installed. IIRC, you don't need to add any wires to the harness.
Ty Garvin
Ty
That's my other problem. I have mechanical gauges installed at the moment. So in order to fix this. I need to put back in factory sending units. And probably order a new printed circuit .
gmachinz
Harnessworx Inc
Iowa
Jabin
Heres a screen shot of the pin-outs....should clarify at least the differences between the years.
u157777
