Clicking in Steering Gear?
Mango
JacksonWyoming
Gil
I Have Clicking in steering gear box, Only notice when not moving, Louder when engine off.
New Red Head Box 10 monthes ago, I have bigger tires on it 31`s, what i have researched is possible cracked frame??
Will do a inspection when i finish work and get it up on the lift
Help
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Could be the frame. Could be pitman arm rod ends, could be tie rods. I've got some balljoints that pop every now and then.
Ive noticed my one pitman arm end that has the boot facing up collects water sometimes and starts popping after it washes the grease out.
I would jack it up and see if it still does it while there's no tension on the tires and suspension. Make sure you pin point. It could be in the column or the box or the mechanical linkages. Get a helper to turn the wheel all sorts of ways while you inspect.
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Help
Could be turn signal switch.
Mango
JacksonWyoming
Gil
Its in the box?? Put it on lift at Work no frame cracks, Tighten rag joint, New Leaf spring bushings, ( Energy Susoension ) Greases all Joints, Does not make a sound whrn tires off the ground, Not the turn signal switch, Good One! Contacted Red Head Going through all the checks with them also
Mango
JacksonWyoming
Gil
Hey All
Just installed a new Red Head Steering gear box under warranty and Clicking gone ???
Mango
JacksonWyoming
Gil
yes i am wondering the same ??
Mango
JacksonWyoming
Gil
OK All
My steering is still very stiff and does not return back to center on its own while completing a turn?
New red head with 4,000 miles should be broken by now, all joints greased and fairly new, The only thing I can think or is that i used a Pickle Fork to Remove the Drag Link to the Pitman arm Seens to move freely by hand? Also I have a inline filter Cloged?
sallyjeank10
