Last night, checked the cam degree after getting the crank sprocket on (that tool is a gem!)
I rechecked TDC with the piston stop and reset it to zero. I put the digital micrometer directly on the lip of the lifter, and zero’d it out. Knowing I wanted to do the intake centerline method, (stay with me here) I went to .200 lobe lift on either side of the lobe, recorded the degrees on either side and did the math. 104.75. Well, sh!t. Supposed to be 108. I tore everything down, rechecked TDC with the piston stop, reset the micrometer. And…same result. Not the end of the world, I have a 9-key way sprocket, but I felt I was doing something wrong (one or more of you already know- I was just spitballing an amount of lift to choose on either side.)
I remembered watching a good JAMSI video on YouTube when they were building a 383. He mentioned that with some cams, THE LOBES ARE NOT SYMMETRICAL. Eureka!
The way he does it, he chooses max lift on the micrometer, and goes down either side .050 to zero in from the top, rather than the base, which was more or less what I was doing (or at least, I was a lot further down the lobe). Using his method, I’m at 107 degrees intake centerline. Now, that’s better. Actually, perfect. As the chain wears and it retards, it’ll be on the money someday.
So now that you feel like you’ve read the bible or the IRS tax code on GMSB, I’ll just say that I’m starting my day in a good mood. I’ll double check everything today, and if it checks out I’ll move on to installing the rest of the pistons.
