Carpet size
mxer147
Colorado
Jack
k20
After dying the carpet and trying to fit it, appears it’s not wide enough. Appears to be 1-2” short on each side along the angle. I haven’t cut the floor shift hole in fear I will make it mostly useless if it truly isn’t wide enough and it fits a different model. It doesn’t have much stretch either? Maybe a heat gun will make it stretch some? Do I have the wrong carpet for the hump height? Did it shrink in the 180F dye bath? I removed it from a 1985 k20 automatic. The dark brown color looks good.
kkgp81
Kelley
Low hump carpet in a high hump truck? If you took it out of a high hump and going back to a high hump there shouldn't be an issue. What year is the truck you are putting it in? There is a hump difference in the years.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Different between years and between 2 wheel and 4x4
mxer147
Colorado
Jack
k20
1983 K20, I wasn’t paying close attention to low or high hump when I removed it. It used to have a beat up rubber mat in it so I can’t compare it to that either. I assumed the tag on the carpet covered my 83 floor shift 4 WD.
kkgp81
Kelley
The first thing I see on the tag is it list from 73-87 which I would assume is a huge red flag other than maybe it was a trim to fit ordeal but it's finished off on the side so that doesn't seem to be the case.
mxer147
Colorado
Jack
k20
It fit the 85 K20 4WD, auto perfectly.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I think 4WD Automatic is high hump and manual gearbox 4WD is low hump.
mxer147
Colorado
Jack
k20
This k30 hump looks very similar to mine which I found on the WWW. And, could explain why it doesn’t fit.
jwtlake
