Carbon/charcoal filter element
Briano
Ohio
Suburban
I have an ‘83 GMC Suburban,the air cleaner assembly has 2 filters, one is the typical paper filter,the other is a steel mesh filter loaded with carbon or charcoal granules. I believe it is to scrub the smell of lingering gas fumes left in the carb. Does anyone know exactly what it is and which vehicles had it?
wixthedog
Magnolia, Texas
I could be wrong but doesn't that attach to the valve cover for the PVC circuit input?
Big Chip
Michigan
Kevin
C35
I think they all had it. Try a Purolator B20009.
Briano
Ohio
Suburban
Purolator B20009 is the small breather assembly,not questioning that,I’m talking about that large steel mesh filter ring. It’s loaded with carbon/ charcoal granules .
Craig 85
Nashville, TN
454/TH-400/NP205
I thought this was a noise filter similar to new vehicles to cut intake noise on full acceleration. Keith Seymore said it's actually a flame retarder. I've had it on 3 of my '81 & up squares with 454's. I removed it from all 3 as I assume it reduces air flow some what. I haven't had an engine fire yet. It's stuck on with some really good adhesive.
SirRobyn0
Rob
I have no idea which vehicles did or didn't have it. It may have been partially to absorb vapors, but the Q-jets had bowl vet lines to the charcoal canister so there would have been a fairly minimal amount of vapor. I always thought that it's main purpose was a flame arrestor, as if to protect the air cleaner in the event of a back fire up the intake. And if Keith says that's what they are for then that's it.
Briano
Ohio
Suburban
Briano
Ohio
Suburban
Thanks. It sure was glued down!!
Big Chip
Michigan
Kevin
C35
Ha! I wasn’t even looking at that. Sorry!
kparris
