Carb to TBI
usar17
PA
K20 Silverado
TBI350/700r4/NP208
more pics...
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Wow, that looks like a much later throttle body...like 90+
Does this truck have a PTO on it? Thats the only reason I could see having that bracket on the front of the throttle body, for a speed control cable.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Nothing currently or that I've seen may have been. Just electronic brakes. This gonna be an issue?
Jims86
Patterson,Ca
5.7 TBI
Nope. Like I said earlier, you will have to find a throttle body with the proper linkage.
Heres a suggestion. I have a proper throttle shaft to send you. I think you should take the shaft, and the throttle body to a machine shop, and have bushings installed, along with this throttle shaft, and then your ready to rock.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
What years for throttle bodies would work?
Jims86
Patterson,Ca
5.7 TBI
since you have the round TPS plug, I would say 1991 with 700r4, or anything truck with that trans 87-91 if you dont mind changing the plug.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Same number of pins right? Just cut and splice the plug?
....if I find a 87-91 350 with a 700r4...couldn't I pull the ecm and tranny lock up wires? Or is it a different harness all together?
And any provisions I need to worry about for cruise control?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
And can I get a photo of what this throttle plate is supposed to look like so that I get the right throttle body
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Thanks man :) I'm gonna hit my favorite yard. They have around 20 trucks and suburbans there between 87-91
Jims86
Patterson,Ca
5.7 TBI
yup, just splice, same wire colors.
dont worry about cruise unless you have it. it can be added.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
You referring to the throttle position sensor or the tranny?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Just to make this a little easier for me can u identify these? I'm assuming fuel relay is one
Jims86
Patterson,Ca
5.7 TBI
The one on the right is the fuel relay with that red wire with plug, and the one on the left is the kickdown relay for the TH 400.
MrMarty51
Eastern Montana
Martin
Thank You,every bit of information helps.I was`nt sure what that relay was for,the one on the left.
NateP350
