Can't get rid of play in the steering
Camar068
Air Force Supporting Member
10 yrs Air Force
I'd just push a piece of 6 in channel iron up against the frame rails in front of the sway bar drill 3 holes per side bolt it up, it would hold the frame rails parallel you could get fancier but that would add a ton of ridgity,cheap and easy. 6x2 channel 3/16ths
you mean parallel/against the frame or one piece from drivers side to passenger side frame?
Passenger side to drivers side,just like a receiver hitch.
Camar068
10 yrs Air Force
Wow, didn't know they were that flexy those years! I'll have to take a closer look at one next time I see. I was actually going to use the later rear crossmember at the tail of the bed on my 77 as I figured the holes would create some additional access that I could have used.
It just depends on the usage of the truck. Especially at the rear, the later crossmember with holes in it will be fine for most trucks. But I'm working toward my truck being a Pro-Touring/Auto-X build, so I need the stiffness. I'll also be replacing my rear crossmember with a TinWorks fab unit that is stiffer
But the '81-up 2wd crossmembers have so much material cut out of them, even a street truck/cruiser could benefit from a stouter version. I've seen a handful of guys swap in the 4wd one since it's solid. Here's a pic of mine, note the huge holes and that where it rivets to the frame has legs cuz there's more material taken out of the sides. That was part of the weight reduction they did for '81-up, I think they saved 300lbs or so over an '80-down truck.
Steppin Razor
Houston
S
C10 silverado
Okay,so now we know where the play is,make sure the shaft isn't slipping around inside the pitman arm,if it isn't,then you need a steering box. Did you say you adjusted this box? Did you follow the factory procedure I posted? Just the little screw on top doesn't cut it. You have to set end thrust first.
I did.
I thought as much re: steering box. I was hesitant ordering the cardone, but it's not like there are a lot of choices.
I did.
Have you made sure that steering shaft isn't moving inside the pitman arm,?As in the steering box out put is turning but moves before it starts moving the pitman arm. Have you laid under the truck and watched for what moves vs.what doesn't move,while some one else works the steering wheel? Little side to side motions,then bigger side to side motions.
Camar068
10 yrs Air Force
mine was going that a few months ago. A few ooga-dooga's with an impact took care of that.
mtbadbob
Montana
Bob
V20
If you go to Les Schwab and ask them to tell you what is wrong with the steering - they will diagnose it for free in the hopes that you will pay them to fix it. Just ask for a repair quote, and it will list all the issues that they can find. The specialize in these types of diagnostics.
You trust those monkeys working at tire shops???
Chevy 88
Canada
f7t6
GMC
Trust? Yes - I trust their repairs, and their diagnosis. I also trust them to WAY over diagnose, suggesting that you replace far more parts than what is necessary or even reasonable. I also trust them to be the most expensive shop without a thousand miles. So if the US government hired a tire shop - that's who they would hire. I would never go there for paid repairs, but you have to admit - if price was no issue, they would make sure your rig is reliable.
erikm00
erik
k5
My steering to was very sloppy, definitely on curvy roads at highways at speed. Thought I would drift lane and hit someone. Drove like that for a decade, wouldn't let anyone else drive K5. Replace gear box twice come to realize U bolts were loose. It was riding up and down leaf spring on driver side. Found leaf center and wrenched those Nutz down!
Steppin Razor
Houston
S
C10 silverado
I have not had a chance to crawl under and watch as I've been moving, but will do next week. I put the impact on the other end of the pitman arm, but not the castle nut on the other end.
@erikm00 , I've got coil springs up front, but good tip.
chevdude
jeff
Bought a K10 last weekend that had a lot of play in the steering.
Seller said that all the steering components are good. He thought maybe the steering box was bad.
I got under there and had someone turn the steering wheel back and forth.
Immediately saw that both front and rear drag links were sloppy.
Replaced them. Adjusted so steering wheel is centered.
The test beat proved that the issue was solved.
Hilllbilly
PNW
Elon
k20, c10
Check your wheel bearings, maybe they're loose :waytogo: :favorites13:
duncan_schawalder
