cannot get brakes to pump up 79 square
curse
49002 portage mi
kyle
I replaced the master cylinder with a new one about a year ago. I haven't driven it any distance since I've been repairing other things. replaced rear shoes, rear wheel cylinders, rear rubber brake hose, both rear solid lines, and solid lines from rear to the prop valve. I removed the switch from the proportioning valve and I can see the piston is centered and not "triggered". The pedal will not pump up to bleed the brakes and after a loooong time gravity bleeding the rears finally got fluid.
Question is...is there anything I should need to do like have the key on? Maybe I'm missing something? I don't think so but thought i'd ask before getting another master cylinder. Thanks.
Poppy 87
Bloomingdale GA
R10 Silverado
Did you bench-bleed the master cylinder prior to installation?
curse
49002 portage mi
kyle
Yes I did. Funny thing is the pedal would pump up before I replaced everything.
curse
49002 portage mi
kyle
I was opening the bleeder screws on wheel cylinders with a wrench and when the wrench hit the axle I figured it was far enough. It was about a quarter turn but no brake fluid would come out. I tried bleeding again today but when the wrench hit the axle I removed the wrench and turned the bleeders a tiny bit by hand and fluid flowed and a lot ofair was in lines. That was a first and now I have a pedal.
  • Like
Reactions: WFO
cpender
