Can I shift a 4L80E with the solenoids?
remco
vledder the netherlands
remco
C 30
I find this
1-2 Solenoid 2-3 Solenoid
1st Gear On Off
2nd Gear Off Off
3rd Gear Off On
4th Gear On On
I gues that the lockup also uses a solenoid.
It,s not real rocket sience to make a set of flappy paddles to do that.
Would just need a small gear lever for P-R-N-D
Have a new steering colum in the truck without the shifter.
Dom,t have the computer for the Trans, and prefer to shift in manual.
I know that it will shift a bit hard this way , but will it work?
Thanks
ajd89
Central Michigan
andrew
Here ya go! All you need is some light switches!
damon18
