Can anyone identify this axle type?
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Was told it’s a 1982 ff.
not sure if it’s a dually rear wheel or single rear wheel and or if it came off a 4x4 or a rear wheel drive.
any help would be much appreciated
HOTFOOT
northwest ct
michael
gmc k3500 srw
I know it’s a one ton shocks on the inside of springs, maybe a cab and chassis. would have Dana 70 for dual wheel pu
nvrenuf
Mobile, Al.
Looks like a single rear wheel 14 bolt. Need to measure the center pin width and WMS width to be more specific.
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
I bought it
It measured about 40 inches in between spring perch to spring perch.
everything I measured from the 1986 suburban 4x4 was almost exact as to the to this 14 FF “full floater”.
hopefully this will hold up and not blow up after one 3 hours of drifting.
it sure looks a whole lot more bullet proof.
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
I’m also wondering is the axle tubes are going to be the same diameter as the current 14bolt SF.
Single wheel, 3/4 ton, '83 and older.
Iirc, the axle tubes are the same diameter on the semi-floater.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
If you blow up the center section, I have a MINT g80 for you.
TubeTruck
East TN
Denis
Suburban K10
LQ9
I want to know how they got it on top of that pile. Those suckers weight a little over 500lbs lol
14 Bolt Full Floater with captive drums. Meaning you have to pull the hubs to get the drums off.
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Skid steer to load it.
1940 ford 9n with boom pole to unload it.
Bonanza 77
