- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Might as well bore it now.
Why? I can get pistons for the 4.080 bore spec. The 4.077 spec wasnt right after I rechecked it today.
Because the main reason not to bore is saving the cost of new pistons. Now you need new pistons anyway. Might as well bore it so you know it's nice and true, run the rings you want on new pistons, and then drive it for 100K.
I agree 100%. What's another $150 - $175 or so for machine work to the block and have it completly brand new motor. You'd be a fool not to if you are buying pistons now.
So bored it to 40 over? I bet its more than $175 bore the 390.
What are these spots on my camshaft? Is it ok to still use cam or should I replace.
Piston ring groove cleaner with a spin dial. I'll check it out.
We use a groove cleaner in the shop but if ya break a old ring in half ya got a ring groove cleaner for free
Use cast rings on a hone job (re ring) the molys or moly top ring set won't seal up rite and gap ur rings also........dont make the refresh hard and expensive ok
So there you go Dave, now person #2 giving the same advice. But, do keep in mind with a fresh bore and those new pistons you are talking about, you'll be able to go with your chromolly or molly rings that your teacher told you about. You might want to also update your teacher and let him know, you don't use upgraded rings for a re ring because they are not likely to seat. Just saying !!!
Welcome KonaK !!! Nice to have some more knowledgable and experienced help on board.
My teacher heard of the moly rings not seating right but he never had that problem on a rering. He also never heard of boring a block for new pistons either. He told me my cylinders were fine and just needed honed to touch up the cross hatch.
You obviously don't get it. NOONE is saying you have to bore the block for new pistons. What is being said is, YOU MAY AS WELL bore the block since you are buying new pistons and have a brand new fresh clean bore that will ensure round cylinders, no ridge, and no wear at all. Pistons will likely be the same price for STD size or .030 over or .040 over. You'd also be increasing your cubic inch a little bit, maybe 6 inches or so, and also raise your compression a hair for more power. Its all up to you. With some of this info you're getting from your teacher, I'd have to wonder if could really reccomend his class for new student recruits.
I build alot of performance motors at work & yes you can reuse a cam with new lifters, we have done it alot.....just break the cam and New lifters in like a new cam setup with zink additive...
