c20 frame help
cooper_joe
ohio
cooper
gmc c10
I have a c20 frame for a project, do they make a kit to fix this rust at the driver side rear leaf springs and what is that thing coming from the gas tank? is that the cause of the rust? both sides for comparison
Moderator
You will need to cut out the rusty spots and section in good pieces of donor frame.
Not sure about those tank drain fittings. They look factory-installed, but I've never seen such a thing. Was this frame originally under a motor home pickup?
Old Guy Bill
KY
Bill
My truck had rust on one side of the frame there.
LMC has both the outer & inner spring perches, the frame can be repaired there when they're out of the way.
Strick
Dunn, NC
Harold
C20 Crew
All years, or just the early ones?
My 82 has them & all the D30 CUCV that I've had were the same. I haven't seen the drain valve on gas trucks.
HS
Moderator
HS
Well I'll be damned. Never noticed them before. I don't remember seeing them on my buddy's '89 R3500 that I had here for a while.
  • Like
Reactions: WFO
jw23655
