Brights flashing with right turn
J-SQUARED
Westfield, IN
Josh
K1500
Been working on my 85 K1500 front wiring. It was taken apart when I got it so I don't know the previous working condition. I tested all 4 headlights to find all functions work. I did some research and opted for the LMC headlight relay kit to operate my lights. I see there is a strong emphasis on grounds with the headlights so I made sure the grounds were clean and adequate. I have 4 total grounds. 2 on the LMC kit and two in the OEM harness. Since I opted for the LMC kit I went ahead and cut out all of the EOM plugs/wiring and replaced the plug that connects to the LMC kit with a new one. I also opened up all the OEM internal splices in the loom and cut those out and re did them with heat shrink. Some were pretty nasty. I did re-use the OEM wiring to marker/turn and the wiring going to the new plug I put in. Everything looked good and all copper was clean and bright every where I cut into it. I tested everything and it looked good so I re-assembled everything. I went to re-test and found zero functionality on headlights when I turned them on. Park/markers all worked. When I actuated the brights they came on and then when I toggled back the headlights were on. I figured it was a tired MFS and moved on. I then check signals and noticed with low beams everything works as it should. When I turn the high beams on the right turn signal indicator in the cab glows dimly. When I turn the right turn signal on all 4 brights flash on the truck. Although this looks pretty cool, not exactly ideal, lol. I'm about 80% convinced the problem is in the MFS as it is finicky and I can move it around a bit making the headlights turn on and off. My other thought is maybe somehow voltage is back feeding through ground somehow through the turn signal circuit. It was late when I got done last night so I haven't tested anything as I was irritated it gave me fits when I thought I had it whipped...
Is there a simple way to test the MFS?
Oh, rear light harness was pulled out of bed and hanging so I completely cut it out of the equation. I also tested the 4 wires back there and all four function as intended.
What does everyone think?
idrivea2002golf
San Diego
Spencer
Not sure yet.
I'm assuming you're using incandescent style bulbs for the turn signals. I would start by making sure the bulbs in the 4 corners of the truck are seated correctly and not burned out (parking nor turn). I had an issue, just last weekend, where I upgraded my rears to LEDs and the turn signal turned on the parking lamps for that side. The front bulb was toast and making a connection inside the glass filament. Since relays require about .00001 amp to trigger, it would take almost nothing to send the signal to the LMC harness relay and flash the brights.
Jgonick
West Texas
Joel
You are correct-
This usually means voltage is using DK BLU-15 wire as a ground. (Right turn signal)
Check your main ground from your radiator support to the battery.
attachment is a list of main grounds.
Grounds-
Think of a partially clogged drain- a little water everything drains correctly- add too much water and it backs up. If the ground is not sufficient, electricity will try to find another path to ground.(like the turn signal)
J-SQUARED
Westfield, IN
Josh
K1500
i checked a few things when i got home and saw the front marker was just dim... The left turn signal has a new bulb and new base was making poor contact and when i touched it the marker shone brightly again. I had no idea the electrical was so touchy on these trucks!
J-SQUARED
Westfield, IN
Josh
K1500
You are correct-
Grounds-
Your attachment is helpful. Line 2, 3, and 8 are non existent on my truck. However, when i test ground on the core support studs it seems very strong! I will look into those two and see if that fixes things!
Thanks!
J-SQUARED
Westfield, IN
Josh
K1500
You are correct-
Grounds-
I should have mentioned for line 2 its exists, just differently. mine is alternator bracket to frame, not battery to frame. I think i can change it pretty easily.
idrivea2002golf
San Diego
Spencer
Not sure yet.
Electrical is a bear and can be stupid touchy. Especially in a 40 year old light socket. There are replacement bulb holders you can crimp on to help. I find using a screw driver to adjust the metal tabs helps too. I'm also a huge proponent of putting a dab of dielectric grease into the socket before the bulb. Doesn't help with contact but it does help with vibration and oxidation resistance.
As long as the engine has a good ground to the battery,then alternator bracket to frame is fine for chassis ground. But you do need three good grounds 1 to body,1 to engine,1 to frame.
J-SQUARED
Westfield, IN
Josh
K1500
I cleaned and checked all grounds. Ran a heavy cable directly to the core support. Cleaned and installed the ground that was hanging off the back of the block to the firewall. All are beautiful! Still flashes the brights... I also cleaned and scrubbed the bulkhead connection and re greased it with fresh dielectric to be sure there wasn't any jumping in that connector. When i probe the green wire out of the bulkhead i'm still getting voltage with the right turn. Im now starting to think maybe something behind the cluster as the brights and turn are completely separate in the column. im not getting any right turn indicator light on the cluster either.
J-SQUARED
Westfield, IN
Josh
K1500
Its definitely a bear! I purchased and installed two new turn signal basses with new bulbs. I'm not overly excited of the quality of them but they seem to be working fine...
idrivea2002golf
San Diego
Spencer
Not sure yet.
I'm working on an engine swap in my square and between working on the engine I've put some effort into the lights/electrical. I had an issue where the parking lights would flash when I was running the blinkers in the rear. Turns out the missing ground on the front bulbs was passing current through the bulb and back down to the parking lights in the rear. Removed the front bulb... bob's your uncle. Worked perfectly.
J-SQUARED
Westfield, IN
Josh
K1500
Both of my front turn signal bases are new. I have no rear lights wired or hooked up at all. The front turn signals and markers seem to work and I get offset flashing of the turn/marker. I will fiddle with those 4 front lights tonight and see if it affects things.
Thanks
J-SQUARED
Westfield, IN
Josh
K1500
Does anyone know how much of this is routed through the cluster or printed board on the back? Mine is in extremely poor condition and has been heavily altered with aftermarket gauges.
J-SQUARED
Westfield, IN
Josh
K1500
Well, I found a solution but not sure what the fix will be. I removed the cluster hoping the short was in there somewhere. It is, maybe. The cluster I have has been all but beat to crap and altered and half of the printed board cut off and removed! Once unplugged the lights are all functioning normally. My fear is I will get my replacement and when I plug that main plug back into the replacement it will go back to doing what it was... Hopefully not but we'll see I guess.
Carterized
