Brake lights only work with the turn signal on
Rusty K20
Boise, ID
Bryce
Hi guy's, I'm having an issue with my brake lights. The running lights, turn signals and hazards all work fine but the brake lights only work when I signal one way or the other. I have no idea what could be causing this, I changed the flasher for the turn signal but that did nothing. Any help would be much appreciated
crpntr78
Missouri
Check your grounds at the tail light harness.
Westislander
Massachusetts
Gregg
I agree sounds like a ground problem
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
May be bad turn signal switch under steering wheel. Had something similar on a previous truck I owned.
Rusty K20
Boise, ID
Bryce
I don't think it is a ground problem, none of my lights worked before I went through and cleaned all the grounds I could find, but I will look to see if I missed any
Is there anyway of checking to see if it is the turn signal switch without replacing it?
Rusty K20
Boise, ID
Bryce
It's definitely not a ground issue
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Yes- you will need a known good one and plug it in under the dash for testing .
One thought might be to disconnect the switch and see if the brake lights work.
Long connector to the left of the brake light switch.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The brake switch should have power on the orange wire, and on the white wire with the brake pedal pressed. Power then goes up to the turn signal switch, and comes out to each individual brake light on the same wire as the turn signals. If the turn signals work, you can assume the wiring and bulbs are good. Before doing anything else, push and pull the hazard light switch on the column a few times. If that doesn’t do anything, most likely the turn signal switch is defective and needs replaced.
Scrambler-Cafe
